How do you use the LWIP hardware checksum
已解决
跳至解决方案
2,395 次查看
calvinday
I am using the K66 and would like to use the ENET hardware checksum.
I have set:
    ENET_TFWR |= ENET_TFWR_STRFWD(1);
    ENET_TACC |= ENET_TACC_IPCHK(1) | ENET_TACC_PROCHK(1);
and defined
     CHECKSUM_BY_HARDWARE
but the checksum does not work. Is there something else I should do?
1 解答
2,042 次查看
Hui_Ma
You also need to enable the ENET_TACC[SHIFT16] & ENET_RACC[SHIFT16] bits.
Wish it helps.
best regards,
Ma Hui
在原帖中查看解决方案
1 回复
2,043 次查看
Hui_Ma
Wish it helps.
best regards,
Ma Hui
