How do you set up a semaphore (atomic test and set) for a k21 prossesor?
1,554 次查看
brentgreenwald
We are trying to make a semaphore where if the critical section is in use it will send back a signal stating it is busy. We went through the bare metal machine code on the arm to try to figure it out but we still don't know how to do it. we are doing it on a MK21FN1M0VMC12 MCU on the TWR-K21F120M dev board.
标签 (2)
1,406 次查看
Hui_Ma
Semaphore is an Embedded RTOS component.
Customer could find NXP MQX RTOS provide that component and NXP also provides KSDK software supports FreeRTOS and uc-OS III RTOS.
Wish it helps.
Ma Hui
1,407 次查看
Hui_Ma
Wish it helps.
Ma Hui
