How do I enable the internal oscillator on the K60?
2,866 次查看
TravisHidlay
Hello all,
Does anyone know how to enable the internal oscillator on the K60?  I'm using MQX 3.7 / CW 10.1 along with the TWR-K60 dev kit.
Thanks in advance.
2,501 次查看
TravisHidlay
Never mind,  I was getting confused about how the clock on the kinetis works... As I understand it you need either an external clock chip or, if using the internal clock, an external crystal/resonator?
2,502 次查看
TravisHidlay
