How do I build the uTasker Rowley_Kinetis example project in CrossWorks?
ed_graham
I am trying to build the uTasker "Rowley_Kinetis" example project in CrossWorks (see attachment uTaskerExampleProject.PNG).  However, when I load the project and try to compile it (without modification), I immediately see errors (see attachment RowleyUtaskerExampleProject_compilationErrors.PNG).
What am I doing wrong?  Do I need to modify some of the files, add preprocessor definitions or otherwise alter the build settings in order to get it to compile?
