How do I access my SD card ?
2,416 次查看
randyseedle
How do I access my SD card ? Is there a device driver for SDHC for my FRDM-K64 board ?
What file system should I be using to access the SD card ? Are there any examples ? Is there any documentation of this process ?
2,184 次查看
Masmiseim
Senior Contributor I
Hello Randy,
Download the official SDK for your Board from here:
https://mcuxpresso.nxp.com/en/select
You will find an example for fatFS in it, together with many other examples and drivers
Best Regards
2,184 次查看
mjbcswitzerland
Specialist V
Or use https://github.com/uTasker/uTasker-Kinetis
More powerful interface than FatFs, integrated into USB-MSD, works with memory sticks and directly accessible by FTP or web browser.
https://www.youtube.com/watch?v=VJ7YveF4_8g
Documented: http://www.utasker.com/docs/uTasker/uTasker_utFAT.PDF
Out-of-the-box for FRDM-K64F: http://www.utasker.com/kinetis/FRDM-K64F.html
All operation (FAT, K64, Interrupts, DMA, SDHC, SD card) simulated in Visual Studio for ease of developing debugging, learning.
Supported as free open source or professional version.
Mark
Complete Kinetis solutions for professional needs, training and support:http://www.utasker.com/kinetis.html
uTasker: supporting >1'000 registered Kinetis users get products faster and cheaper to market
2,184 次查看
mspenard603
Most of the SDK's out there are based around Chan FatFs (http://elm-chan.org/fsw/ff/00index_e.html). Take a look in your SDK's example projects,  you'll find something there.
