How can i setup ezport do not response "READ" command ?
rqbh
I do not want ezport response "READ" commond from out side? how can do that ?
Hui_Ma
Hi Kevin,
The EzPort "READ" commander can not access Flash memory when the chip in secured state.
So, customer need to config Flash configuration field(0x40C, related definition please check FTFE_FSEC register description) to secure the chip.
Wish it helps.
Ma Hui
