Hi,Is there any possibility to interface SD card with tower kit?
1,406 次查看
nimmisatheendra
I am using Tower kit with K53, now I want to store the data on SD card, Is there any possibility for the same??
If I will get any sample code for SD card interfacing???
1,241 次查看
jeremyzhou
Hi Nimmi,
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you.
The TWR-K53N512 has the SD socket, and  I'd highly recommend you to refer to the SD demo code below.
Sd-Card Fat file system Project for Freescale Kinetis.rar
Ping
1,241 次查看
nimmisatheendra
Hi Jeremyzhou,
Thank you for your suggestion. There is a problem, I am using IAR workbench. Can you please provide me the sample code for IAR workbench??
1,241 次查看
jeremyzhou
Hi Nimmi,
You can also find the sdhc_cdcard demo in the ~\SDK_2.0_FRDM-K64F\SDK_2.0_FRDM-K64F\boards\frdmk64f\driver_examples after you install the KSDK 2.0.
Please go to download the KSDK 2.0 through the link as below.
Software Development Kit for Kinetis MCUs|NXP
Hope it helps.
Ping
