Hard fault: arm_dot_prod_q15() function ?
2,687件の閲覧回数
jerrylian
I am testing the following CMSIS-DSP function with MCUXpresso-IDE:
* arm_dot_prod_q15();
* The program finishes this function with correct result, but then goes to HardFault_Handler(), and never returns!
What could be wrong?
Thanks!
Jerry
2,338件の閲覧回数
jerrylian
Hi, Robin:
Thanks for your information, but I solved my problem with the following post:
How to import CMSIS-DSP examples?
Thanks again!
Jerry
2 返答(返信)
2,338件の閲覧回数
Robin_Shen
Hi Jerry,
Please check this post by colleague Derek Snell and the links provided by him:  Tracking down Hard Faults
I hope this helps.
Robin
2,339件の閲覧回数
jerrylian
Hi, Robin:
Thanks again!
Jerry
