HTTP Server, frdmk66f_httpssrv_mbedTLS_freertos
a8Chcx
I tried the sample project "frdmk66f_httpssrv_mbedTLS_freertos" and it works fine...
Then, I disabled "WEBSOCKET" and "MbedTLS", it works fine as the regular HTTP server.
I found the following issue during my stress testing:
If I connect the server by using browser, it works fine. Then I close the browser, I can see the heap used is increasing by around 6K. If I do this again, the heap is increasing by around 6K again....
Can anybody tell me why the heap size keep increasing and the used heap is not released after the browser closed? How to fix this problem?
Christie
Pavel_Hernandez
This is unexpected behavior, please let me do a report and when I have more details I will contact.
Pavel
a8Chcx
Hi Pavel,
I am waiting for your side testing result and let me know any recommendation?
Christie
Pavel_Hernandez
Which SDK example/version you used?
Pavel
a8Chcx
Hi Pavel,
I am using MCUXpresso IDE 11.5.0 with SDK 2.11.0 for FRDM-K66F board.
Christie
Pavel_Hernandez
Thanks for your report we will effort to resolve this issue in the next update, unfortunately, I do not have a date for this update I apologize for this inconvenience may cause.
Pavel
a8Chcx
Hi Pavel,
I am using this function for our controller and really need this to be fixed ASAP.
Could you let me know when you have updated this and let me know the details about the fixes?
So, I can update in my project as well to resolve the issue that I have for now?
Thank you very much for your help!
Christie
Pavel_Hernandez
I found this thread maybe could help you, Re: Memory Leak problem in LPC1788 with FreeRTOS ... - NXP Community
Pavel
