HDMI to UVC
HDMI to UVC
2,951 次查看
philhale
Is there a way to convert a live HDMI stream and output a USB Video Class (UVC) output so a PC can see the stream from within Skype or some other webcam type application? How about the other way around? Connect a webcam to an NXP MCU and convert it to HDMI?
3 回复数
2,828 次查看
kerryzhou
Hi PHIL HALE ,
  Please check the RT UVC appliation note:
https://www.nxp.com/docs/en/application-note/AN12103.pdf
  Whether it is useful to you or not?
  Or maybe you need to use the I.MX processor instead of the MCU.
Wish it helps you!
Kerry
2,828 次查看
philhale
Thank you, Kerry.
I read that doc last night. It doesn't explain how one would receive an HDMI stream and re-encode it into a format that the MCU can convert into a USB stream.
2,828 次查看
kerryzhou
Hi PHIL HALE,
    MCU seems difficult to meet your HDMI request.
    Today, I help you check with our processor engineer, they tell me you can try I.MX6 and I.MX8.
    More detail, please go to this link, and create the new question post, our I.MX processor engineer will help you.
    i.MX Processors
Wish it helps you!
Kerry
