We aren’t going to use the Real Time Clock module in the MK20DX256VLL7. How do I connect the following pins:
1) VBAT (pin 30)
2) XTAL32 (pin 28)
3) EXTAL32 (pin 29)
Do I ground these pins or leave them unconnected?
Solved! Go to Solution.
You can leave VBAT floating, same goes for XTAL32 and EXTAL32, you can also leave the XTAL pins grounded.
