Getting error while trying to run USB stack V4.1.1?
2,008件の閲覧回数
karthikpoojary
Currently using keil ide I am getting following error while trying to run any demo from USB stack
.\RAM\USB_CDC.axf: Error: L6218E: Undefined symbol asm (referred from main_kinetis.o).
ラベル(2)
タグ(3)
1,874件の閲覧回数
kerryzhou
Hi Karthik Poojary,
  Did you use the MDK project?
  If yes, please add CMSIS in the options define:
Then save the project, and build again, you will find the error have disappeared.
Wish it helps you!
If you still have question, please contact me!
Jingjing
1,875件の閲覧回数
kerryzhou
Hi Karthik Poojary,
Wish it helps you!
Jingjing
