Generate a single PWM cycle in eFlexPWM without using reload interrupt
zorrotz
In eFlexPWM peripheral, is it possible to generate a single PWM cycle, but without using the reload interrupt to finish the cycle?
Thanks in advance
EdwinHz
Hi @zorrotz,
Thanks for the clarifications. After looking into it, I have arrived at the conclusion that the only way of doing single PWM pulses is indeed by using the reload interruption.
BR,
Edwin.
EdwinHz
Hi @zorrotz,
Could you please share what your part number is, as well as the SDK and IDE versions that you are using?
BR,
Edwin.
zorrotz
Hi @EdwinHz ,
My part number is MKV46F128VLL16.
The IDE version is MCUXpresso IDE v11.9.0 [Build 2144] and the SDK is 2.8.0.
EdwinHz
Hi @zorrotz,
BR,
Edwin.
%3CLINGO-SUB%20id%3D%22lingo-sub-2066213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGenerate%20a%20single%20PWM%20cycle%20in%20eFlexPWM%20without%20using%20reload%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2066213%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EIn%20eFlexPWM%20peripheral%2C%20is%20it%20possible%20to%20generate%20a%20single%20PWM%20cycle%2C%20but%20without%20using%20the%20reload%20interrupt%20to%20finish%20the%20cycle%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%20in%20advance%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Generate%20a%20single%20PWM%20cycle%20in%20eFlexPWM%20without%20using%20reload%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067571%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59428%22%20target%3D%22_blank%22%3E%40zorrotz%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThanks%20for%20the%20clarifications.%20After%20looking%20into%20it%2C%20I%20have%20arrived%20at%20the%20conclusion%20that%20the%20only%20way%20of%20doing%20single%20PWM%20pulses%20is%20indeed%20by%20using%20the%20reload%20interruption.%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Generate%20a%20single%20PWM%20cycle%20in%20eFlexPWM%20without%20using%20reload%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067084%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186731%22%20target%3D%22_blank%22%3E%40EdwinHz%3C%2FA%3E%20%2C%3C%2FP%3E%3CP%3EMy%20part%20number%20is%20MKV46F128VLL16.%3C%2FP%3E%3CP%3EThe%20IDE%20version%20is%20MCUXpresso%20IDE%20v11.9.0%20%5BBuild%202144%5D%20and%20the%20SDK%20is%202.8.0.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2066460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Generate%20a%20single%20PWM%20cycle%20in%20eFlexPWM%20without%20using%20reload%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2066460%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59428%22%20target%3D%22_blank%22%3E%40zorrotz%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20share%20what%20your%20part%20number%20is%2C%20as%20well%20as%20the%20SDK%20and%20IDE%20versions%20that%20you%20are%20using%3F%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E
