Gcov integration on FRDM K66F
886 次查看
Shravan_hudekar
I want to try gcov code coverage integration on MK66F, which is already been implemented on MK64F.
https://mcuoneclipse.com/2014/12/26/code-coverage-for-embedded-target-with-eclipse-gcc-and-gcov/
But the issue is coverage_stub.c  file contain header files compatible with MK64F but not with  MK66F which in turns giving an error to all function calls.
following are files:
types.h
stat.h
unistd.h
stdint.h
errno.h
And kinetis sdk 2.x is not having frdm k66f board utility required for processor expert code generation.
881 次查看
ErichStyger
Specialist I
Hi @Shravan_hudekar ,
I wrote a more recent tutorial with the MCUXpresso IDE and SDK here:
https://mcuoneclipse.com/2021/02/01/tutorial-gnu-coverage-with-mcuxpresso-ide/
I don't have a K66, but I recommend to use that one as a starting point.
I hope this helps,
Erich
