GUI Converter Utility Convert 3.0.0 and Myriad Pro font
johndanile
Has anyone come across when using the Utility Converter that you are able to choose "import font", Select a font from the pull down menu and then it states that it is "unable to load font" popup message. We are trying to use Myriad Pro but it also happens with other fonts. I can successfully import stand fonts like "Arial" "Calbri" but not "Myriad Pro" which i have on my computer.
Tags (2)
soledad
