Freedom KL25z128 with USB Stackv4.03 compile Err
2,207 次查看
changfuzhao
Hi, I am working on KL25z128, and  USB V4.03, after I import example project "USB_HID_MOUSE_DEVICE_MQX_Lite_MKL25Z128_PEx"
and complie it, I got a error :
C:/CW_10_4_workplace/USB_HID_MOUSE_DEVICE_MQX_Lite_MKL25Z128_PEx/Generated_Code/types.h:61:25: error: conflicting types for 'boolean'
does any one have same problem?
Or, does anyone succeeful import and run this project
Thanks a lot
1,944 次查看
Hui_Ma
Hi Changfu,
I would recommend customer to use the latest USB Stack V4.1.1:
USB_STACK_V4.1.1
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MEDICALUSB&fpsp=1&tab=Design_Tools_Ta...
Please let me know if you still meet problem with the latest USB stack.
Wish it helps.
1,945 次查看
Hui_Ma
Hi Changfu,
USB_STACK_V4.1.1
Wish it helps.
1,944 次查看
changfuzhao
Tanks, after I change to V4.11, they are working fine, even still has many warning, and I //#endif in usb_descriptor.h at line 509
Thanks a lot
