Freedom Board FRDM-KL46Z Board
1,275 次查看
andyfischer
Hi there, I just received my Freedom Board FRDM-KL46Z Board. So as I was Trying to start it up my PC wasnt able to install the driver somehow. So i Tryed to install it manually but didnt work. Status now is that I stuck in the BOOTLOADER Mode, its the only way I can start the Board. what can I do ? is there a way to reboot it ??
1,181 次查看
kerryzhou
Hi Andy fischer,
   Please tell me what the PC system you are using?
  Please go to this link:
PEmicro - P&E Microcomputer Systems: Over 30 years as an Industry leader in Embedded Systems Develop...
Download the P&E driver and install it at first, then plug your board to the PC.
Please also download the Firmware Apps.zip, you will find the according opensda firmware.
In Firmware Apps.zip, you can following the BOOTUPDATEAPP_release_notes.txt to update your bootloader at first.
Kerry
