Much thanks for responding. I am not sure I can use this because of the following concerns:
1. The K12 is an M4, the KL25 I belive is an M0.
2. The URL describes the need for 3 different software packages, IAR, PE driver suite, and additional PE components. We require all firmware be written in IAR.
But since you mentioned an M0, freeRTOS does have a K60 IAR demo project. The K60, like the K12 is an M4, but with more stuff. Can I use that port? If so, do you know if there anything I must do to the port to make it work for a K12 device?
Hab
