Forcing a Thumb address
2,871 次查看
ERussell
I am working with a k60 using CW10.2. I would like to force a label in an assembly file to be at a thumb address, i.e. with the LSB set, but have not been able to do this.  Can anyone tell me how to do this?
Thanks.
2,733 次查看
Nouchi
Senior Contributor II
Cortex M processors only support thumb and thumb-2 instructions.
 http://www.arm.com/products/processors/cortex-m/cortex-m4-processor.php
2,733 次查看
konrada
Whether you need to add one to your code address depends on what instruction you use to jump there (B/BL vs BX/BLX), so adding the one to the label is dangerous.
What are you trying to do?
2,732 次查看
ERussell
I was attempting to implement the QK Scheduler  portion of the Quantum Leaps QP code. There is a warning, at least for the GNU C compiler, to insure that the address of an assembly label is a thumb address in the PendSV_Handler routine. As it turned out there was no problem and the function is working correctly with no intervention on my part, so I assummed that the fist responder was correct.
Thanks for responding.
2,734 次查看
Nouchi
