Flexio to SD card
Flexio to SD card
1,068件の閲覧回数
lacouturepatric
I am using the TWR-K80F150M board, MCUXpresso IDE v10.0.0_344 and SDK_2.2_TWR-K80F150M.
For my project, i should acquire 4 serial data at 16 MHz which must be saved into sd card. For the acquisition, I use FLEXIO module.
Do you have a SW example that transfer high speed data from flexio shift buffer to SD card, for example Flexio SPI  to SD card ?
Thank you in advance.
Patrice
タグ(3)
0 返答(返信)
