FlexCAN filter question
1,642件の閲覧回数
davidsherman
Senior Contributor I
I'm using the KE18F512, and I have the FlexCAN working in FIFO mode.  MCR[IDAM] = 0, CTRL2[RFFN] = 0, MCR[IRMQ]=1, CTRL2[EACEN] = 1, CTRL2[MRP] = 0.  The message buffers from 8-15 are being used for transmission only.  I am trying to filter standard frames, so I have the 8 FIFO filters set for 0x40000000, which should require the IDE bit.  However, both standard and extended frames are being received.  What am I doing wrong?
2 返答(返信)
1,377件の閲覧回数
jorge_a_vazquez
Hi David Sherman
Public information related with KE18F512 part number is not available yet, you need to contact your FAE to get support on this.
Sorry for the inconveniences that this may cause you.
Jorge Alcala
1,377件の閲覧回数
davidsherman
The question was not about KE18, only about FlexCAN.  I got it figured out though.
