Flashing using CodeWarrior
renj007
I have a doubt regarding flashing binaries to target with Codewariror IDE.
Tried flashing binaries of formats .afx ,.bin,.S19 record.Flashed successfully in all former cases.
My doubt is, Can we flash intel hex record to target using this same codewarrior IDE provided Flash programmer ???
Any help is appreciated !!!
apanecatl
Senior Contributor II
You can't use .hex files directly, you'd have to convert them to any of the Flash programmer supported formats
