Flash Programming software for Tower Board
3,090 次查看
renjithvamanan
Currently I am using the Code Warrior "Flash To Target" option to program the Tower board through the OSBDM/OSJTAG interface.
Is there a standalone programming software available for this purpose?
Renjith
2,904 次查看
Hui_Ma
Hi Renjith,
Besides of CodeWarrior embedded "Flash to Target" tool, so far there is no free standalone software for OSBDM debugger tool.
Ma Hui
4 回复数
2,904 次查看
pgo
Senior Contributor V
Hi Renjith,
It is possible to reprogram the OSBDM BDMS included in the Tower Products with USBDM which has free programming software.
However, to do this you need a HCS08 programmer.
bye
2,904 次查看
Carlos_Musich
Hi Renjith,
Please take a look to PROG for ARM Cortex from P&E Micro: http://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320138
Hope this helps!
Carlos
2,904 次查看
renjithvamanan
Hi Carlos,
Thanks for the info.
Is there any free software available ?
I just need the software since the programming is supported by Tower board OSBDM hardware.
Renjith
2,905 次查看
Hui_Ma
Hi Renjith,
Ma Hui
