FTM Timer Confusion
FTM Timer Confusion
Jana_muralidharan
So, I am trying to start the timer FTM0/FTM1 it, upon running of the timer code it stucks at the HardFault why but the same code with FTM2 works perfectly fine why??
the not working code
#include "MKE02Z4.h"
/* ================= GLOBALS ================= */
volatile uint8_t uartFlag = 0;
/* ================= PROTOTYPES ================= */
void init_clock(void);
void init_uart0(void);
void init_FTM1(void);
void UART_Send(const char *s);
/* ================= FTM1 ISR ================= */
void FTM1_IRQHandler(void)
    /* Clear overflow flag (write 0 while set) */
    FTM1->SC &= ~FTM_SC_TOF_MASK;
    uartFlag = 1;
/* ================= MAIN ================= */
int main(void)
    init_clock();
    init_uart0();
    init_FTM1();
    UART_Send("FTM1 Initialized\r\n");
    while (1)
        if (uartFlag)
            uartFlag = 0;
            UART_Send("A\r\n");
        __WFI();   /* wait for interrupt */
/* ================= CLOCK INIT ================= */
     * Assume internal clock already configured by SDK startup
     * Bus clock = 32 MHz
    SIM->BUSDIV = 0x01;   /* divide by 1 */
/* ================= UART0 INIT ================= */
    /* Enable UART0 clock */
    SIM->SCGC |= SIM_SCGC_UART0_MASK;
    /* UART0 pin select (TX/RX) */
    SIM->PINSEL |= SIM_PINSEL_UART0PS_MASK;
    /* Disable TX inversion (important!) */
    SIM->SOPT &= ~SIM_SOPT_TXDME_MASK;
     * 9600 baud @ 32 MHz
     * SBR = 32e6 / (16 * 9600) ≈ 208
    UART0->BDH = 0x00;
    UART0->BDL = 53;
    UART0->C1 = 0x00;
    UART0->C2 = UART_C2_TE_MASK | UART_C2_RE_MASK;
/* ================= FTM1 INIT ================= */
    /* Enable FTM1 clock */
    SIM->SCGC |= SIM_SCGC_FTM1_MASK;
    __DSB();
    /* ---- VERY IMPORTANT ORDER (KE02 SAFE) ---- */
    /* Stop counter completely */
    FTM1->SC = 0;
    /* Disable write protection (WRITE ONCE) */
    FTM1->MODE = FTM_MODE_WPDIS_MASK;
    /* Reset counter */
    FTM1->CNTIN = 0;
    FTM1->CNT   = 0;
     * 32 MHz / 128 = 250 kHz
     * 250000 ticks = 1 second
    FTM1->MOD = 249999;
    /* Enable overflow interrupt, prescaler = 128 */
    FTM1->SC = FTM_SC_PS(7) | FTM_SC_TOIE_MASK;
    /* Enable NVIC */
    NVIC_EnableIRQ(FTM1_IRQn);
    /* START TIMER (LAST STEP ONLY) */
    FTM1->SC |= FTM_SC_CLKS(1);
/* ================= UART SEND ================= */
    while (*s)
        while (!(UART0->S1 & UART_S1_TDRE_MASK));
        UART0->D = *s++;
 the working code
void init_FTM2(void);
/* ================= FTM2 ISR ================= */
void FTM2_IRQHandler(void)
    FTM2->SC &= ~FTM_SC_TOF_MASK;
    uartFlag = 1;
int main(void)
    init_clock();
    init_uart0();
    init_FTM2();
    UART_Send("FTM2 Initialized\r\n");
    while (1)
        if (uartFlag)
            uartFlag = 0;
            UART_Send("A\r\n");
    UART0->BDH = 0x00;
    UART0->BDL = 53;
    UART0->C1 = 0x00;
/* ================= FTM2 INIT ================= */
    /* Enable FTM2 clock */
    SIM->SCGC |= SIM_SCGC_FTM2_MASK;
    __DSB();
    FTM2->SC = 0;
    FTM2->MODE = FTM_MODE_WPDIS_MASK;
    /* Reset counter */
    FTM2->CNTIN = 0;
    FTM2->CNT   = 0;
    FTM2->MOD = 249999;
    FTM2->SC = FTM_SC_PS(7) | FTM_SC_TOIE_MASK;
    /* Enable NVIC */
    NVIC_EnableIRQ(FTM2_IRQn);
    FTM2->SC |= FTM_SC_CLKS(1);
    while (*s)
        UART0->D = *s++;
Jana_muralidharan
I actually found the error
It is that I used registers that are specific to only FTM2,
So, after removing the unwanted registers it worked perfectly fine.
And I found out that HardFault Error will only occur when, We use register which are not there in the first place.
Hey and thanks for your attention to this query thanks.....
Hi @Jana_muralidharan
Please debug to check whether the FTM1 clock is enabled and verify if the counter register is functioning properly.
Alice
Jana_muralidharan
%3CLINGO-SUB%20id%3D%22lingo-sub-2269247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFTM%20Timer%20Confusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESo%2C%20I%20am%20trying%20to%20start%20the%20timer%20FTM0%2FFTM1%20it%2C%20upon%20running%20of%20the%20timer%20code%20it%20stucks%20at%20the%20HardFault%20why%20but%20the%20same%20code%20with%20FTM2%20works%20perfectly%20fine%20why%3F%3F%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%3CU%3E%3CEM%3E%3CSTRONG%3Ethe%20not%20working%20code%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FU%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%23include%20%22MKE02Z4.h%22%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20GLOBALS%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avolatile%20uint8_t%20uartFlag%20%3D%200%3B%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20PROTOTYPES%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20init_clock(void)%3B%0Avoid%20init_uart0(void)%3B%0Avoid%20init_FTM1(void)%3B%0Avoid%20UART_Send(const%20char%20*s)%3B%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20FTM1%20ISR%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20FTM1_IRQHandler(void)%0A%7B%0A%20%20%20%20%2F*%20Clear%20overflow%20flag%20(write%200%20while%20set)%20*%2F%0A%20%20%20%20FTM1-%26gt%3BSC%20%26amp%3B%3D%20~FTM_SC_TOF_MASK%3B%0A%0A%20%20%20%20uartFlag%20%3D%201%3B%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20MAIN%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Aint%20main(void)%0A%7B%0A%20%20%20%20init_clock()%3B%0A%20%20%20%20init_uart0()%3B%0A%20%20%20%20init_FTM1()%3B%0A%0A%20%20%20%20UART_Send(%22FTM1%20Initialized%5Cr%5Cn%22)%3B%0A%0A%20%20%20%20while%20(1)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20if%20(uartFlag)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20uartFlag%20%3D%200%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20UART_Send(%22A%5Cr%5Cn%22)%3B%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20__WFI()%3B%20%20%20%2F*%20wait%20for%20interrupt%20*%2F%0A%20%20%20%20%7D%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20CLOCK%20INIT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20init_clock(void)%0A%7B%0A%20%20%20%20%2F*%0A%20%20%20%20%20*%20Assume%20internal%20clock%20already%20configured%20by%20SDK%20startup%0A%20%20%20%20%20*%20Bus%20clock%20%3D%2032%20MHz%0A%20%20%20%20%20*%2F%0A%20%20%20%20SIM-%26gt%3BBUSDIV%20%3D%200x01%3B%20%20%20%2F*%20divide%20by%201%20*%2F%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20UART0%20INIT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20init_uart0(void)%0A%7B%0A%20%20%20%20%2F*%20Enable%20UART0%20clock%20*%2F%0A%20%20%20%20SIM-%26gt%3BSCGC%20%7C%3D%20SIM_SCGC_UART0_MASK%3B%0A%0A%20%20%20%20%2F*%20UART0%20pin%20select%20(TX%2FRX)%20*%2F%0A%20%20%20%20SIM-%26gt%3BPINSEL%20%7C%3D%20SIM_PINSEL_UART0PS_MASK%3B%0A%0A%20%20%20%20%2F*%20Disable%20TX%20inversion%20(important!)%20*%2F%0A%20%20%20%20SIM-%26gt%3BSOPT%20%26amp%3B%3D%20~SIM_SOPT_TXDME_MASK%3B%0A%0A%20%20%20%20%2F*%0A%20%20%20%20%20*%209600%20baud%20%40%2032%20MHz%0A%20%20%20%20%20*%20SBR%20%3D%2032e6%20%2F%20(16%20*%209600)%20%E2%89%88%20208%0A%20%20%20%20%20*%2F%0A%20%20%20%20UART0-%26gt%3BBDH%20%3D%200x00%3B%0A%20%20%20%20UART0-%26gt%3BBDL%20%3D%2053%3B%0A%0A%20%20%20%20UART0-%26gt%3BC1%20%3D%200x00%3B%0A%20%20%20%20UART0-%26gt%3BC2%20%3D%20UART_C2_TE_MASK%20%7C%20UART_C2_RE_MASK%3B%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20FTM1%20INIT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20init_FTM1(void)%0A%7B%0A%20%20%20%20%2F*%20Enable%20FTM1%20clock%20*%2F%0A%20%20%20%20SIM-%26gt%3BSCGC%20%7C%3D%20SIM_SCGC_FTM1_MASK%3B%0A%20%20%20%20__DSB()%3B%0A%0A%20%20%20%20%2F*%20----%20VERY%20IMPORTANT%20ORDER%20(KE02%20SAFE)%20----%20*%2F%0A%0A%20%20%20%20%2F*%20Stop%20counter%20completely%20*%2F%0A%20%20%20%20FTM1-%26gt%3BSC%20%3D%200%3B%0A%0A%20%20%20%20%2F*%20Disable%20write%20protection%20(WRITE%20ONCE)%20*%2F%0A%20%20%20%20FTM1-%26gt%3BMODE%20%3D%20FTM_MODE_WPDIS_MASK%3B%0A%0A%20%20%20%20%2F*%20Reset%20counter%20*%2F%0A%20%20%20%20FTM1-%26gt%3BCNTIN%20%3D%200%3B%0A%20%20%20%20FTM1-%26gt%3BCNT%20%20%20%3D%200%3B%0A%0A%20%20%20%20%2F*%0A%20%20%20%20%20*%2032%20MHz%20%2F%20128%20%3D%20250%20kHz%0A%20%20%20%20%20*%20250000%20ticks%20%3D%201%20second%0A%20%20%20%20%20*%2F%0A%20%20%20%20FTM1-%26gt%3BMOD%20%3D%20249999%3B%0A%0A%20%20%20%20%2F*%20Enable%20overflow%20interrupt%2C%20prescaler%20%3D%20128%20*%2F%0A%20%20%20%20FTM1-%26gt%3BSC%20%3D%20FTM_SC_PS(7)%20%7C%20FTM_SC_TOIE_MASK%3B%0A%0A%20%20%20%20%2F*%20Enable%20NVIC%20*%2F%0A%20%20%20%20NVIC_EnableIRQ(FTM1_IRQn)%3B%0A%0A%20%20%20%20%2F*%20START%20TIMER%20(LAST%20STEP%20ONLY)%20*%2F%0A%20%20%20%20FTM1-%26gt%3BSC%20%7C%3D%20FTM_SC_CLKS(1)%3B%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20UART%20SEND%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20UART_Send(const%20char%20*s)%0A%7B%0A%20%20%20%20while%20(*s)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20while%20(!(UART0-%26gt%3BS1%20%26amp%3B%20UART_S1_TDRE_MASK))%3B%0A%20%20%20%20%20%20%20%20UART0-%26gt%3BD%20%3D%20*s%2B%2B%3B%0A%20%20%20%20%7D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%26nbsp%3Bthe%20working%20code%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-cpp%22%3E%3CCODE%3E%23include%20%22MKE02Z4.h%22%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20GLOBALS%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avolatile%20uint8_t%20uartFlag%20%3D%200%3B%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20PROTOTYPES%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20init_clock(void)%3B%0Avoid%20init_uart0(void)%3B%0Avoid%20init_FTM2(void)%3B%0Avoid%20UART_Send(const%20char%20*s)%3B%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20FTM2%20ISR%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20FTM2_IRQHandler(void)%0A%7B%0A%20%20%20%20%2F*%20Clear%20overflow%20flag%20(write%200%20while%20set)%20*%2F%0A%20%20%20%20FTM2-%26gt%3BSC%20%26amp%3B%3D%20~FTM_SC_TOF_MASK%3B%0A%0A%20%20%20%20uartFlag%20%3D%201%3B%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20MAIN%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Aint%20main(void)%0A%7B%0A%20%20%20%20init_clock()%3B%0A%20%20%20%20init_uart0()%3B%0A%20%20%20%20init_FTM2()%3B%0A%0A%20%20%20%20UART_Send(%22FTM2%20Initialized%5Cr%5Cn%22)%3B%0A%0A%20%20%20%20while%20(1)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20if%20(uartFlag)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20uartFlag%20%3D%200%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20UART_Send(%22A%5Cr%5Cn%22)%3B%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20__WFI()%3B%20%20%20%2F*%20wait%20for%20interrupt%20*%2F%0A%20%20%20%20%7D%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20CLOCK%20INIT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20init_clock(void)%0A%7B%0A%20%20%20%20%2F*%0A%20%20%20%20%20*%20Assume%20internal%20clock%20already%20configured%20by%20SDK%20startup%0A%20%20%20%20%20*%20Bus%20clock%20%3D%2032%20MHz%0A%20%20%20%20%20*%2F%0A%20%20%20%20SIM-%26gt%3BBUSDIV%20%3D%200x01%3B%20%20%20%2F*%20divide%20by%201%20*%2F%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20UART0%20INIT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20init_uart0(void)%0A%7B%0A%20%20%20%20%2F*%20Enable%20UART0%20clock%20*%2F%0A%20%20%20%20SIM-%26gt%3BSCGC%20%7C%3D%20SIM_SCGC_UART0_MASK%3B%0A%0A%20%20%20%20%2F*%20UART0%20pin%20select%20(TX%2FRX)%20*%2F%0A%20%20%20%20SIM-%26gt%3BPINSEL%20%7C%3D%20SIM_PINSEL_UART0PS_MASK%3B%0A%0A%20%20%20%20%2F*%20Disable%20TX%20inversion%20(important!)%20*%2F%0A%20%20%20%20SIM-%26gt%3BSOPT%20%26amp%3B%3D%20~SIM_SOPT_TXDME_MASK%3B%0A%0A%20%20%20%20%2F*%0A%20%20%20%20%20*%209600%20baud%20%40%2032%20MHz%0A%20%20%20%20%20*%20SBR%20%3D%2032e6%20%2F%20(16%20*%209600)%20%E2%89%88%20208%0A%20%20%20%20%20*%2F%0A%20%20%20%20UART0-%26gt%3BBDH%20%3D%200x00%3B%0A%20%20%20%20UART0-%26gt%3BBDL%20%3D%2053%3B%0A%0A%20%20%20%20UART0-%26gt%3BC1%20%3D%200x00%3B%0A%20%20%20%20UART0-%26gt%3BC2%20%3D%20UART_C2_TE_MASK%20%7C%20UART_C2_RE_MASK%3B%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20FTM2%20INIT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20init_FTM2(void)%0A%7B%0A%20%20%20%20%2F*%20Enable%20FTM2%20clock%20*%2F%0A%20%20%20%20SIM-%26gt%3BSCGC%20%7C%3D%20SIM_SCGC_FTM2_MASK%3B%0A%20%20%20%20__DSB()%3B%0A%0A%20%20%20%20%2F*%20----%20VERY%20IMPORTANT%20ORDER%20(KE02%20SAFE)%20----%20*%2F%0A%0A%20%20%20%20%2F*%20Stop%20counter%20completely%20*%2F%0A%20%20%20%20FTM2-%26gt%3BSC%20%3D%200%3B%0A%0A%20%20%20%20%2F*%20Disable%20write%20protection%20(WRITE%20ONCE)%20*%2F%0A%20%20%20%20FTM2-%26gt%3BMODE%20%3D%20FTM_MODE_WPDIS_MASK%3B%0A%0A%20%20%20%20%2F*%20Reset%20counter%20*%2F%0A%20%20%20%20FTM2-%26gt%3BCNTIN%20%3D%200%3B%0A%20%20%20%20FTM2-%26gt%3BCNT%20%20%20%3D%200%3B%0A%0A%20%20%20%20%2F*%0A%20%20%20%20%20*%2032%20MHz%20%2F%20128%20%3D%20250%20kHz%0A%20%20%20%20%20*%20250000%20ticks%20%3D%201%20second%0A%20%20%20%20%20*%2F%0A%20%20%20%20FTM2-%26gt%3BMOD%20%3D%20249999%3B%0A%0A%20%20%20%20%2F*%20Enable%20overflow%20interrupt%2C%20prescaler%20%3D%20128%20*%2F%0A%20%20%20%20FTM2-%26gt%3BSC%20%3D%20FTM_SC_PS(7)%20%7C%20FTM_SC_TOIE_MASK%3B%0A%0A%20%20%20%20%2F*%20Enable%20NVIC%20*%2F%0A%20%20%20%20NVIC_EnableIRQ(FTM2_IRQn)%3B%0A%0A%20%20%20%20%2F*%20START%20TIMER%20(LAST%20STEP%20ONLY)%20*%2F%0A%20%20%20%20FTM2-%26gt%3BSC%20%7C%3D%20FTM_SC_CLKS(1)%3B%0A%7D%0A%0A%2F*%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20UART%20SEND%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20*%2F%0Avoid%20UART_Send(const%20char%20*s)%0A%7B%0A%20%20%20%20while%20(*s)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20while%20(!(UART0-%26gt%3BS1%20%26amp%3B%20UART_S1_TDRE_MASK))%3B%0A%20%20%20%20%20%20%20%20UART0-%26gt%3BD%20%3D%20*s%2B%2B%3B%0A%20%20%20%20%7D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CEM%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20Timer%20Confusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269461%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258109%22%20target%3D%22_blank%22%3E%40Jana_muralidharan%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3EPlease%20debug%20to%20check%20whether%20the%20FTM1%20clock%20is%20enabled%20and%20verify%20if%20the%20counter%20register%20is%20functioning%20properly.%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EBR%3C%2FDIV%3E%0A%3CDIV%3EAlice%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269468%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20Timer%20Confusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269468%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20actually%20found%20the%20error%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIt%20is%20that%20I%20used%20registers%20that%20are%20specific%20to%20only%20FTM2%2C%3C%2FP%3E%3CP%3ESo%2C%20after%20removing%20the%20unwanted%20registers%20it%20worked%20perfectly%20fine.%3C%2FP%3E%3CP%3EAnd%20I%20found%20out%20that%26nbsp%3B%3CSTRONG%3EHardFault%20Error%26nbsp%3B%3C%2FSTRONG%3Ewill%20only%20occur%20when%2C%20%3CEM%3E%3CSTRONG%3EWe%20use%20register%20which%20are%20not%20there%20in%20the%20first%20place.%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20size%3D%225%22%3E%3CSTRONG%3E%3CEM%3EHey%20and%20thanks%20for%20your%20attention%20to%20this%20query%20thanks.....%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
