FTM CnV Update Problem 2
2,938 次查看
Jana_muralidharan
Hi, I got another problem, i previously ask and got solve it is the LDOK register that i was wrong
but even after solving that it still not doing what i ask that is to update the CnV and change the Pulse width please help me this is that code i have been working on
#include "MKE02Z4.h"
#define FTM_MOD     24      // 25 ticks → 1.25us @ 20MHz
#define TICKS_0      7
#define TICKS_1     14
void FTM_Init(void)
    SIM->SCGC |= SIM_SCGC_FTM2_MASK;
    FTM2->MODE = FTM_MODE_WPDIS_MASK | FTM_MODE_FTMEN_MASK;
    FTM2->CNTIN = 0;
    FTM2->CNT   = 0;
    FTM2->MOD   = FTM_MOD;
    FTM2->CONTROLS[0].CnSC =
        FTM_CnSC_MSB_MASK |
        FTM_CnSC_ELSB_MASK;
    FTM2->CONTROLS[0].CnV = TICKS_0;
    /* ENABLE CHANNEL OUTPUT (CRITICAL) */
    FTM2->OUTMASK &= ~(1 << 0);
    /* Initial load */
    *(volatile __UINT32_TYPE__ *)0x4003A098 = 0x0201;
    FTM2->SC = FTM_SC_CLKS(1) | FTM_SC_PS(0);
    *(volatile __UINT32_TYPE__ *)0x4003A064 = 0x00;
static inline void wait_ftm_period(void)
    while(!(FTM2->SC & FTM_SC_TOF_MASK));
    FTM2->SC &= ~FTM_SC_TOF_MASK;
uint32_t word = 0x5555;
int main(void)
    FTM_Init();
    while (1)
        for(int i = 0; i < 16; i++)
            if (word & (1UL << i))
                *(volatile __UINT32_TYPE__ *)0x4003A010 = TICKS_1;
            else
            	*(volatile __UINT32_TYPE__ *)0x4003A010 = TICKS_0;
            /* ARM reload for next PWM cycle */
            /* WAIT ONE PWM PERIOD */
            wait_ftm_period();
7 回复数
2,842 次查看
Hello @Jana_muralidharan
Please use the FTM_UpdatePwmDutycycle() API to update the PWM duty cycle.
For more details, refer to the ftm_simple_pwm demo, where the PWM duty cycle is periodically updated.
* brief Updates the duty cycle of an active PWM signal.
* param base FTM peripheral base address
* param chnlNumber The channel/channel pair number. In combined mode, this represents
* the channel pair number
* param currentPwmMode The current PWM mode set during PWM setup
* param dutyCyclePercent New PWM pulse width; The value should be between 0 to 100
* 0=inactive signal(0% duty cycle)...
* 100=active signal (100% duty cycle)
* return kStatus_Success if the PWM update was successful
* kStatus_Error on failure
status_t FTM_UpdatePwmDutycycle(FTM_Type *base,
ftm_chnl_t chnlNumber,
ftm_pwm_mode_t currentPwmMode,
uint8_t dutyCyclePercent)
Alice
2,763 次查看
Jana_muralidharan
But can you please tell me, in how much cycle that the PWM updates
2,754 次查看
This depends on your application. You can refer to your requirement design.
Regarding this SDK demo, it uses a timer overflow interrupt to update the PWM duty cycle.
Alice
2,935 次查看
Jana_muralidharan
Hey I am the writer of the post And i am working in the WS2812B so i though of using PWM to generate the signal so that why thing thing of changing the Duty cycle so and i want to know Is it possible to do that with this
2,892 次查看
Hi @Jana_muralidharan ]
I'm sorry, I'm a bit confused. Are you asking how to change the duty cycle of the PWM, or are you asking why your duty cycle changed?
Thank you.
Alice
2,848 次查看
Jana_muralidharan
Hello @Alice_Yang,
Yeah i am trying to change the PWM duty cycle for every cycle like for 1st period 30% duty cycle then in the 2nd period 70% duty cycle like that
Is there any procedure to change the PWM duty change
It just stuck at the initially set value that the issue here
430 次查看
lianfu
哈哈 我遇到类似的问题 经过一番折腾 最终解决了。
我在S32K144上同时改变开关频率和占空比,发现频率可以任意改变,但与其同时改变的占空比却总是变不了。最终找到了问题, 问题出在这个位FTM_SC_CLKS上。
FTM一旦初始化完成并启动后,如果想要CnV的值,必须将FTM_SC_CLKS=0,即关掉时钟源,也就是使FTM停止工作。然后再修改CnV,修改完后再FTM_SC_CLKS=1,这样就可以改变占空比了。
我想MKE02Z4和S32K144有相似的FTM,它们的工作机制应该是相同的,你不妨试试。
祝你好运!
%3CLINGO-SUB%20id%3D%22lingo-sub-2267521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFTM%20CnV%20%E6%9B%B4%E6%96%B0%E9%97%AE%E9%A2%98%202%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267521%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E5%97%A8%EF%BC%8C%E6%88%91%E5%8F%88%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BB%A5%E5%89%8D%E9%97%AE%E8%BF%87%EF%BC%8C%E4%B9%9F%E8%A7%A3%E5%86%B3%E4%BA%86%EF%BC%8C%E6%98%AF%20LDOK%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%8D%B3%E4%BD%BF%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%AE%83%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%E6%8C%89%E7%85%A7%E6%88%91%E7%9A%84%E8%A6%81%E6%B1%82%E8%BF%9B%E8%A1%8C%E6%9B%B4%E6%96%B0%20cNV%20%E5%B9%B6%E6%9B%B4%E6%94%B9%20%E8%84%89%E5%86%B2%20%E5%AE%BD%E5%BA%A6%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%E8%BF%99%E6%98%AF%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E7%A0%94%E7%A9%B6%E7%9A%84%E4%BB%A3%E7%A0%81%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-cpp%22%3E%3CCODE%20translate%3D%22no%22%3E%23include%20%22MKE02Z4.h%22%0A%0A%23define%20FTM_MOD%20%20%20%20%2024%20%20%20%20%20%20%2F%2F%2025%20ticks%20%E2%86%92%201.25us%20%40%2020MHz%0A%23define%20TICKS_0%20%20%20%20%20%207%0A%23define%20TICKS_1%20%20%20%20%2014%0A%0Avoid%20FTM_Init(void)%0A%7B%0A%20%20%20%20SIM-%26gt%3BSCGC%20%7C%3D%20SIM_SCGC_FTM2_MASK%3B%0A%0A%20%20%20%20FTM2-%26gt%3BMODE%20%3D%20FTM_MODE_WPDIS_MASK%20%7C%20FTM_MODE_FTMEN_MASK%3B%0A%0A%20%20%20%20FTM2-%26gt%3BCNTIN%20%3D%200%3B%0A%20%20%20%20FTM2-%26gt%3BCNT%20%20%20%3D%200%3B%0A%20%20%20%20FTM2-%26gt%3BMOD%20%20%20%3D%20FTM_MOD%3B%0A%0A%20%20%20%20FTM2-%26gt%3BCONTROLS%5B0%5D.CnSC%20%3D%0A%20%20%20%20%20%20%20%20FTM_CnSC_MSB_MASK%20%7C%0A%20%20%20%20%20%20%20%20FTM_CnSC_ELSB_MASK%3B%0A%0A%20%20%20%20FTM2-%26gt%3BCONTROLS%5B0%5D.CnV%20%3D%20TICKS_0%3B%0A%0A%20%20%20%20%2F*%20ENABLE%20CHANNEL%20OUTPUT%20(CRITICAL)%20*%2F%0A%20%20%20%20FTM2-%26gt%3BOUTMASK%20%26amp%3B%3D%20~(1%20%26lt%3B%26lt%3B%200)%3B%0A%0A%20%20%20%20%2F*%20Initial%20load%20*%2F%0A%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A098%20%3D%200x0201%3B%0A%0A%20%20%20%20FTM2-%26gt%3BSC%20%3D%20FTM_SC_CLKS(1)%20%7C%20FTM_SC_PS(0)%3B%0A%0A%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A064%20%3D%200x00%3B%0A%7D%0A%0Astatic%20inline%20void%20wait_ftm_period(void)%0A%7B%0A%20%20%20%20while(!(FTM2-%26gt%3BSC%20%26amp%3B%20FTM_SC_TOF_MASK))%3B%0A%20%20%20%20FTM2-%26gt%3BSC%20%26amp%3B%3D%20~FTM_SC_TOF_MASK%3B%0A%7D%0A%0Auint32_t%20word%20%3D%200x5555%3B%0A%0Aint%20main(void)%0A%7B%0A%20%20%20%20FTM_Init()%3B%0A%0A%20%20%20%20while%20(1)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20for(int%20i%20%3D%200%3B%20i%20%26lt%3B%2016%3B%20i%2B%2B)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20if%20(word%20%26amp%3B%20(1UL%20%26lt%3B%26lt%3B%20i))%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A010%20%3D%20TICKS_1%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20else%0A%20%20%20%20%20%20%20%20%20%20%20%20%09*(volatile%20__UINT32_TYPE__%20*)0x4003A010%20%3D%20TICKS_0%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20ARM%20reload%20for%20next%20PWM%20cycle%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20*(volatile%20__UINT32_TYPE__%20*)0x4003A098%20%3D%200x0201%3B%0A%0A%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20WAIT%20ONE%20PWM%20PERIOD%20*%2F%0A%20%20%20%20%20%20%20%20%20%20%20%20wait_ftm_period()%3B%0A%20%20%20%20%20%20%20%20%7D%0A%20%20%20%20%7D%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%202%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258109%22%20target%3D%22_blank%22%3E%40Jana_muralidharan%3C%2FA%3E%5D%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E6%9C%89%E7%82%B9%E7%B3%8A%E6%B6%82%E4%BA%86%E3%80%82%E4%BD%A0%E6%98%AF%E5%9C%A8%E9%97%AE%E5%A6%82%E4%BD%95%E6%94%B9%E5%8F%98%20PWM%20%E7%9A%84%E5%8D%A0%E7%A9%BA%E6%AF%94%EF%BC%8C%E8%BF%98%E6%98%AF%E5%9C%A8%E9%97%AE%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BD%A0%E7%9A%84%E5%8D%A0%E7%A9%BA%E6%AF%94%E5%8F%91%E7%94%9F%E4%BA%86%E5%8F%98%E5%8C%96%EF%BC%9F%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EBR%3C%2FDIV%3E%0A%3CDIV%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%202%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267535%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%98%BF%E6%88%91%E6%98%AF%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E7%9A%84%E4%BD%9C%E8%80%85%E6%88%91%E6%AD%A3%E5%9C%A8%20WS2812B%20%E5%B7%A5%E4%BD%9C%E6%89%80%E4%BB%A5%E6%88%91%E6%83%B3%E7%94%A8%20PWM%20%E6%9D%A5%E7%94%9F%E6%88%90%E4%BF%A1%E5%8F%B7%E6%89%80%E4%BB%A5%E4%B8%BA%E4%BB%80%E4%B9%88%E8%A6%81%E6%94%B9%E5%8F%98%E5%8D%A0%E7%A9%BA%E6%AF%94%E6%89%80%E4%BB%A5%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E7%94%A8%E8%BF%99%E4%B8%AA%E6%9C%89%E5%8F%AF%E8%83%BD%E5%81%9A%E5%88%B0%E5%90%97%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%202%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258109%22%20target%3D%22_blank%22%3E%40Jana_muralidharan%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%20%3CCODE%20translate%3D%22no%22%3EFTM_UpdatePwmDutycycle()%3C%2FCODE%3E%20API%20%E6%9B%B4%E6%96%B0%20PWM%20%E5%8D%A0%E7%A9%BA%E6%AF%94%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%E6%9C%89%E5%85%B3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%20%3CCODE%20translate%3D%22no%22%3Eftm_simple_pwm%3C%2FCODE%3E%20%E6%BC%94%E7%A4%BA%EF%BC%8C%E5%85%B6%E4%B8%AD%20PWM%20%E5%8D%A0%E7%A9%BA%E6%AF%94%E5%AE%9A%E6%9C%9F%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%20style%3D%22background-color%3A%20%23ffffff%3B%20padding%3A%200px%200px%200px%202px%3B%22%3E%0A%3CDIV%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20'Courier%20New'%3B%20font-size%3A%2010pt%3B%20white-space%3A%20pre%3B%22%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*!%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20*%20%E7%AE%80%E8%A6%81%E6%9B%B4%E6%96%B0%E6%9C%89%E6%BA%90%20PWM%20%E4%BF%A1%E5%8F%B7%E7%9A%84%E5%8D%A0%E7%A9%BA%E6%AF%94%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20*%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E*%20%3C%2FSPAN%3E%3CSPAN%3E%E5%8F%82%E6%95%B0%3C%2FSPAN%3E%3CSPAN%3E%E5%9F%BA%20FTM%20%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E5%9F%BA%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E*%20%3C%2FSPAN%3E%3CSPAN%3E%E5%8F%82%E6%95%B0%3C%2FSPAN%3E%3CSPAN%3EchnlNumber%20%E9%80%9A%E9%81%93%2F%E9%80%9A%E9%81%93%E5%AF%B9%E7%BC%96%E5%8F%B7%E3%80%82%E5%9C%A8%E7%BB%84%E5%90%88%E6%A8%A1%E5%BC%8F%E4%B8%8B%EF%BC%8C%E5%AE%83%E4%BB%A3%E8%A1%A8%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20*%20%E9%80%9A%E9%81%93%E5%AF%B9%E7%BC%96%E5%8F%B7%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E*%20%3C%2FSPAN%3E%3CSPAN%3E%E5%8F%82%E6%95%B0%3C%2FSPAN%3E%3CSPAN%3EcurrentPwmMode%20PWM%20%E8%AE%BE%E7%BD%AE%E6%97%B6%E8%AE%BE%E7%BD%AE%E7%9A%84%E5%BD%93%E5%89%8D%20PWM%20%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E%E5%8F%82%E6%95%B0%3C%2FSPAN%3E%20%3CSPAN%3EdutyCyclePercent%20%E6%96%B0%20PWM%20%E8%84%89%E5%86%B2%E5%AE%BD%E5%BA%A6%EF%BC%9B%E8%AF%A5%E5%80%BC%E5%BA%94%3C%2FSPAN%3E%E4%BB%8B%E4%BA%8E%200%20%E5%88%B0%20100%20%E4%B9%8B%E9%97%B4%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20*%200%20%3D%20%E9%9D%9E%E6%B4%BB%E5%8A%A8%E4%BF%A1%E5%8F%B7%EF%BC%880%25%20%E5%8D%A0%E7%A9%BA%E6%AF%94%EF%BC%89...%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20*%20100%3D%E6%9C%89%E6%BA%90%E4%BF%A1%E5%8F%B7%EF%BC%88100%25%20%E5%8D%A0%E7%A9%BA%E6%AF%94%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20*%20%E5%A6%82%E6%9E%9C%20PWM%20%E6%9B%B4%E6%96%B0%E6%88%90%E5%8A%9F%EF%BC%8C%E5%88%99%E8%BF%94%E5%9B%9E%20kStatus_Success%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20*%20%E5%A4%B1%E8%B4%A5%E6%97%B6%E4%B8%BA%20kStatus_Error%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Estatus_t%3C%2FSPAN%3E%20%3CSPAN%3EFTM_UpdatePwmDutycycle%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EFTM_Type%3C%2FSPAN%3E%3CSPAN%3E*base.UpdatePwmDutycycle%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Eftm_chnl_t%3C%2FSPAN%3E%3CSPAN%3EchnlNumber%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Eftm_pwm_mode_t%3C%2FSPAN%3E%3CSPAN%3EcurrentPwmMode%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%3CSPAN%3EdutyCyclePercent)%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%3EBR%3C%2FDIV%3E%0A%3CDIV%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2268517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%202%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%E4%BD%A0%E5%A5%BD%20%40Alice_Yang%3C%2FA%3E%20%EF%BC%8C%E6%98%AF%E7%9A%84%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%9B%B4%E6%94%B9%E6%AF%8F%E4%B8%AA%E5%91%A8%E6%9C%9F%E7%9A%84%3CBR%20%2F%3E%20PWM%20%E5%8D%A0%E7%A9%BA%E6%AF%94%EF%BC%8C%E6%AF%94%E5%A6%82%E7%AC%AC%E4%B8%80%E5%91%A8%E6%9C%9F%E7%9A%84%2030%25%20%E5%8D%A0%E7%A9%BA%E6%AF%94%E7%84%B6%E5%90%8E%E5%9C%A8%E7%AC%AC%E4%BA%8C%E5%91%A8%E6%9C%9F%2070%25%20%E7%9A%84%E5%8D%A0%E7%A9%BA%E6%AF%94%E5%B0%B1%E5%83%8F%E8%BF%99%E6%A0%B7%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E6%9C%89%E4%BB%80%E4%B9%88%E7%A8%8B%E5%BA%8F%E5%8F%AF%E4%BB%A5%E6%94%B9%E5%8F%98%20PWM%20%E5%8D%A0%E7%A9%BA%E6%AF%94%E5%8F%98%E5%8C%96%E5%90%97%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E5%AE%83%E5%8F%AA%E6%98%AF%E5%81%9C%E7%95%99%E5%9C%A8%E6%9C%80%E5%88%9D%E7%9A%84%E8%AE%BE%E5%AE%9A%E5%80%BC%E4%B8%8A%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%202%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269122%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258109%22%20target%3D%22_blank%22%3E%40Jana_muralidharan%3C%2FA%3E%3C%2FP%3E%0A%3CDIV%3E%E8%BF%99%E5%8F%96%E5%86%B3%E4%BA%8E%E6%82%A8%E7%9A%84%E5%BA%94%E7%94%A8%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E6%82%A8%E7%9A%84%E9%9C%80%E6%B1%82%E8%AE%BE%E8%AE%A1%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%E5%85%B3%E4%BA%8E%E8%BF%99%E4%B8%AA%20SDK%20%E6%BC%94%E7%A4%BA%EF%BC%8C%E5%AE%83%E4%BD%BF%E7%94%A8%E5%AE%9A%E6%97%B6%E5%99%A8%E6%BA%A2%E5%87%BA%E4%B8%AD%E6%96%AD%E6%9D%A5%E6%9B%B4%E6%96%B0%20PWM%20%E5%8D%A0%E7%A9%BA%E6%AF%94%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Alice_Yang_0-1766732600601.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1766732600601.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1766732600601.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Alice_Yang_0-1766732600601.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F371223i55C338270FCC583E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Alice_Yang_0-1766732600601.png%22%20alt%3D%22Alice_Yang_0-1766732600601.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EAlice_Yang_0-1766732600601.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269086%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%202%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269086%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%86%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%91%8A%E8%AF%89%E6%88%91%EF%BC%8CPWM%20%E7%9A%84%E6%9B%B4%E6%96%B0%E5%91%A8%E6%9C%9F%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390288%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FTM%20CnV%20Update%20Problem%202%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390288%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%93%88%E5%93%88%20%E6%88%91%E9%81%87%E5%88%B0%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%20%E7%BB%8F%E8%BF%87%E4%B8%80%E7%95%AA%E6%8A%98%E8%85%BE%20%E6%9C%80%E7%BB%88%E8%A7%A3%E5%86%B3%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8S32K144%E4%B8%8A%E5%90%8C%E6%97%B6%E6%94%B9%E5%8F%98%E5%BC%80%E5%85%B3%E9%A2%91%E7%8E%87%E5%92%8C%E5%8D%A0%E7%A9%BA%E6%AF%94%EF%BC%8C%E5%8F%91%E7%8E%B0%E9%A2%91%E7%8E%87%E5%8F%AF%E4%BB%A5%E4%BB%BB%E6%84%8F%E6%94%B9%E5%8F%98%EF%BC%8C%E4%BD%86%E4%B8%8E%E5%85%B6%E5%90%8C%E6%97%B6%E6%94%B9%E5%8F%98%E7%9A%84%E5%8D%A0%E7%A9%BA%E6%AF%94%E5%8D%B4%E6%80%BB%E6%98%AF%E5%8F%98%E4%B8%8D%E4%BA%86%E3%80%82%E6%9C%80%E7%BB%88%E6%89%BE%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%20%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E8%BF%99%E4%B8%AA%E4%BD%8DFTM_SC_CLKS%E4%B8%8A%E3%80%82%3C%2FP%3E%3CP%3EFTM%E4%B8%80%E6%97%A6%E5%88%9D%E5%A7%8B%E5%8C%96%E5%AE%8C%E6%88%90%E5%B9%B6%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%83%B3%E8%A6%81CnV%E7%9A%84%E5%80%BC%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%B0%86FTM_SC_CLKS%3D0%EF%BC%8C%E5%8D%B3%E5%85%B3%E6%8E%89%E6%97%B6%E9%92%9F%E6%BA%90%EF%BC%8C%E4%B9%9F%E5%B0%B1%E6%98%AF%E4%BD%BFFTM%E5%81%9C%E6%AD%A2%E5%B7%A5%E4%BD%9C%E3%80%82%E7%84%B6%E5%90%8E%E5%86%8D%E4%BF%AE%E6%94%B9CnV%EF%BC%8C%E4%BF%AE%E6%94%B9%E5%AE%8C%E5%90%8E%E5%86%8DFTM_SC_CLKS%3D1%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%B0%B1%E5%8F%AF%E4%BB%A5%E6%94%B9%E5%8F%98%E5%8D%A0%E7%A9%BA%E6%AF%94%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3MKE02Z4%E5%92%8CS32K144%E6%9C%89%E7%9B%B8%E4%BC%BC%E7%9A%84FTM%EF%BC%8C%E5%AE%83%E4%BB%AC%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%9C%BA%E5%88%B6%E5%BA%94%E8%AF%A5%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%EF%BC%8C%E4%BD%A0%E4%B8%8D%E5%A6%A8%E8%AF%95%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E7%A5%9D%E4%BD%A0%E5%A5%BD%E8%BF%90%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
