FSL USB Stack and k64
ソリューションへジャンプ
2,360件の閲覧回数
ERussell
I have been using the FSL USB Stack Version 4.03 (Device) on a k60 processor for a couple of years and am now trying to get the same code running on a k64. So far I am unable to enumerate.  I do get an error interrupt - DMAERR but am not sure how to investigate this further. Has anyone used this version of the USB Stack on a k64? Any ideas about how to figure out the problem?
Elizabeth
ラベル(2)
2,070件の閲覧回数
derek_lau
Disable the MPU
MPU_CESR = 0;
3 返答(返信)
2,070件の閲覧回数
Hui_Ma
Hi Elizabeth,
The USB Stack Version 4.03 is an older USB stack.
So far, customer could consider to use USB Stack V5.0 or Kinetis SDK software, which provides the USB application for K64 product.
Wish it helps.
Ma Hui
2,071件の閲覧回数
derek_lau
Disable the MPU
MPU_CESR = 0;
2,070件の閲覧回数
ERussell
Thank you so much! This cleared the problem and I am able to enumerate.
