FSL USB Stack and k64
ERussell
I have been using the FSL USB Stack Version 4.03 (Device) on a k60 processor for a couple of years and am now trying to get the same code running on a k64. So far I am unable to enumerate.  I do get an error interrupt - DMAERR but am not sure how to investigate this further. Has anyone used this version of the USB Stack on a k64? Any ideas about how to figure out the problem?
Elizabeth
Labels (2)
derek_lau
Disable the MPU
MPU_CESR = 0;
Hui_Ma
Hi Elizabeth,
The USB Stack Version 4.03 is an older USB stack.
So far, customer could consider to use USB Stack V5.0 or Kinetis SDK software, which provides the USB application for K64 product.
Wish it helps.
Ma Hui
derek_lau
Disable the MPU
MPU_CESR = 0;
ERussell
Thank you so much! This cleared the problem and I am able to enumerate.
