FREEDOM-K66F
FREEDOM-K66F
a8Chcx
I am using FREEDOM-K66F board, and I want to enable 24-bit system timer at 1ms interrupt.
There is anyone who can provide me the sample code to do so?
Christie
luis_maravilla
Hello Christie,
Could you help us confirm if you are referring to System Tick Timer [SysTick_DelayTicks] or are you referring to another system timer?
Is there a specific example do you want to test? I would recommend checking on the SDK for FRDM-K66F, if an example could apply for your necessities
Best Regards, Luis
%3CLINGO-SUB%20id%3D%22lingo-sub-2259451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFREEDOM-K66F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2259451%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20using%20FREEDOM-K66F%20board%2C%20and%20I%20want%20to%20enable%2024-bit%20system%20timer%20at%201ms%20interrupt.%3C%2FP%3E%3CP%3EThere%20is%20anyone%20who%20can%20provide%20me%20the%20sample%20code%20to%20do%20so%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EChristie%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2260418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FREEDOM-K66F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2260418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Christie%2C%3C%2FP%3E%0A%3CP%3ECould%20you%20help%20us%20confirm%20if%20you%20are%20referring%20to%20System%20Tick%20Timer%20%5BSysTick_DelayTicks%5D%20or%20are%20you%20referring%20to%20another%20system%20timer%3F%3C%2FP%3E%0A%3CP%3EIs%20there%20a%20specific%20example%20do%20you%20want%20to%20test%3F%20I%20would%20recommend%20checking%20on%20the%20%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fdashboard%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESDK%3C%2FA%3E%20for%20FRDM-K66F%2C%20if%20an%20example%20could%20apply%20for%20your%20necessities%3C%2FP%3E%0A%3CP%3EBest%20Regards%2C%20Luis%3C%2FP%3E%3C%2FLINGO-BODY%3E
