FRDM-KW36 device documentation / SDK
1,959 次查看
tobiasofenberge
Dear NXP community,
I want to start with a project based on the KW36 BLE MCU with the FRDM-KW36 evaluation board. The problem is, that I'm not able to find examples for this MCU. Under the getting started point on the eval. board page is only the SDK for the KW41 MCU.
I'm also missing a datasheet or reference manual on the homepage.
Thank you for your support!
标记 (2)
1,637 次查看
stephanie_m
Sorry for the inconvenience this might cause you, but as this product has not been released yet I do not have any information available to share with you, nonetheless, could you please contact one distributor available in the distributors network to help you with the request?
Estephania
