an4784
an4784
cg0
hello, anybody have an4784 "https://www.nxp.com/docs/en/application-note/AN4874.pdf  " related file AN4784SW.
kerryzhou
Hi Aron,
   As I know, AN4874 don't have the according software, but don't worry, I recommend you refer to AN5219, this application note is also about the KE06 CAN bootloader, this application note already contains the software, please check it from this link:
1. AN5219 application note
https://www.nxp.com/docs/en/application-note/AN5219.pdf
2. AN5219SW
https://www.nxp.com/docs/en/application-note-software/AN5219SW.zip
Wish it helps you!
Kerry
cg0
Hi Kerry
   Thank you very much. It does helpful.
