FRDM-KL46Z
FRDM-KL46Z
1,938 次查看
mattmabile
When i plug the FRDM-KL46Z into my Windows 8.1, 64-bit computer using the OpenSDA USB port the FRDM does not show up as a storage drive like the quick start manual says that it should.
1,739 次查看
Carlos_Mendoza
Hi Matt,
This may be related with the bootloader and firmware version on you board, support for Windows 8/8.1 was added to Bootloader version 1.11 and MSD firmware version 1.14. Please make sure that your board is programmed with Bootloader version 1.11 or higher prior to attempting to update your OpenSDA board with a new firmware application.
You can find more information on how to perform the update and find out what version of Bootloader your board is programmed with on this link:
P&E Microcomputer Systems
Hope it helps!
Carlos Mendoza
Technical Support Engineer
1,739 次查看
mattmabile
Thanks Carlos. I update the firmware and it is working fine now.
Sent from my iPhone
