FRDM-KL25Z: No interrupts on ADC?
1,385 次查看
KenSnyder
I noticed that the document "FRDM-KL25Z Pinouts (Rev 1.0)" says that the FRDM-KL25Z does not support interrupts on ADC.  Is this a board limitation or a processor limitation?
1,125 次查看
Jorge_Gonzalez
Hello Ken:
The Interrupt column refers to digital port interrupts and it is not related to ADC or any other modules. If you double check, you can see only PTA and PTD pins support interrupts (see this).
Regards!,
Jorge Gonzalez
