FRDM-KL03Z TSI function
3,271件の閲覧回数
hans_chen
Hi professors,
I found the KL03z have a slider pad so I think it should be used,but maybe it`s not like KL25z has a Tsi pin for ,and that I am trying to build a TSI function for KL03z then it couldn`t work, Is it a GPIO or the other pins for use?
Then I found a TSS Library can be built for extension development board,but I tried to build with Codewarrior and I failed.Is there anyway can try for it?
Thanks for Helping!
タグ(1)
3,141件の閲覧回数
jingpan
Hi Hans,
KL03 hasn't TSI module. It use GPIO and external circuit to charge and discharge touch electrode.
The TSS_3_1 library support CW. It has KL02 demo. And KL03 and KL02 are almost same.
https://www.nxp.com/products/sensors/other-sensors/touch-sensors/touch-sensing-software:TSS?tab=Desi...
Jing
3,141件の閲覧回数
hans_chen
Hi Jing,
It`s really thanks for your help!
And,can I ask about KL02 function that I tried to connect to KL03 board?
Is there need some settings for KL03Z? I configured the KL03 pin defined and the other. Then I started to Debug,but It came out an error like down below.
Is there something I missed? and can you help me to figure out?
Really appreciate,
Hans
