FRDM-KEAZ128Q8 | OpenSDA problem
2,391 次查看
aelmrn
Hello everyone,
I would kindly like to ask for your help regarding changing the Default Debugging Interface on the FRDM-KEAZ128Q8 development board. The board came with the PEmicro bootloader and the PEmicro Default Debugging Interface, but I would like to use CMSIS instead.
According to the information available on the NXP OpenSDA page (https://www.nxp.com/design/design-center/development-boards-and-designs/OPENSDA), this means that my board is using OpenSDAv1, since both the bootloader and debugging interface are PEmicro by default.
I tried searching for my board on that page to update OpenSDA, but I couldn’t find it listed. I then attempted to use the files provided for the TRK-KEA128 board, but without success. I am familiar with the firmware update procedure (entering bootloader mode and drag-and-dropping the firmware file), but the update did not work.
What makes me particularly suspicious is that the files I downloaded are in .bin format, while according to the table on the NXP page, OpenSDAv1 requires files in .sda / .s19 / .srec format (see the table and download links here: https://www.nxp.com/design/design-center/development-boards-and-designs/OPENSDA?tid=vanOpenSDA#nogo). Further searching did not help, as I could not find the required file formats anywhere.
My main question is: does anyone know how to change the OpenSDA firmware to CMSIS on this board, and is it even possible? I believe it should be, since I have another FRDM-KEAZ128Q8 board that I purchased earlier which is already running on CMSIS firmware, and I don’t recall having to manually switch it from PEmicro.
Any help would be greatly appreciated, and thank you for taking the time to read my post.
A
4 回复数
2,319 次查看
carlos_o
Hi @aelmrn
Thanks for your post.
If the board is not listed, it will not support OpenSDAv2
Apologies for the inconvenience this may cause
2,306 次查看
aelmrn
Hi @carlos_o - Thank you for your response!
I understand that my development board does not support OpenSDAv2, since according to the available information it uses OpenSDAv1. However, I would like to know how to change the OpenSDAv1 firmware from PEmicro to DAP-CMSIS. I have the same development board, the FRDM-KEAZ128Q8, with the DAP-CMSIS firmware, which was ordered somewhat earlier than this new one that came by default with the PEmicro firmware — but I don’t recall having to change the firmware from PEmicro to DAP-CMSIS on that older board.
Also, I think that on your webpage [https://www.nxp.com/design/design-center/development-boards-and-designs/OPENSDA?_gl=1*14qlfnx*_ga*MT...)
the file available for download under **“CMSIS-DAP Debug Application for OpenSDAv1”** is not correctly set up. When selecting the TRK-KEA128 board and pressing “Download Binary,” the downloaded `.bin` file corresponds to the TWR-KM35Z75M board. Moreover, clicking on the adjacent “Source Code” button leads to a deleted page.
Could you please update these files if they are indeed incorrect?
Also, I would greatly appreciate an answer on how to change the OpenSDA firmware application from PEmicro to CMSIS-DAP (to clarify, I do **not** wish to change the OpenSDA version from v1 to v2 or similar).
Thank you in advance for your help.
2,274 次查看
carlos_o
Hi @aelmrn
CMSIS update the debugger software, but it does not include the KEA series (Release CMSIS 6.2.0 · ARM-software/CMSIS_6 · GitHub), the functional debugger to KEA series is PE Micro (PEmicro | 40+ years innovating in the embedded systems space. Flash Programmers, Cloud-based, Automa...).
Apologies the inconvenience this may cause.
2,365 次查看
mara9320
I have similar problem, I hope that there is solution.
%3CLINGO-SUB%20id%3D%22lingo-sub-2179287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-KEAZ128Q8%20%7C%20OpenSDA%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3C%2FP%3E%3CP%3E%E5%85%B3%E4%BA%8E%E6%9B%B4%E6%94%B9%20FRDM-KEAZ128Q8%20%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E7%9A%84%3CEM%3E%E9%BB%98%E8%AE%A4%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%3C%2FEM%3E%EF%BC%8C%E6%88%91%E6%83%B3%E5%AF%BB%E6%B1%82%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E8%AF%A5%E6%9D%BF%E9%99%84%E5%B8%A6%E4%BA%86%20peMicro%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%20PeMicro%20%3CEM%3E%E9%BB%98%E8%AE%A4%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%3C%2FEM%3E%EF%BC%8C%E4%BD%86%E6%88%91%E6%83%B3%E6%94%B9%E7%94%A8%20CMSIS%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%81%A9%E6%99%BA%E6%B5%A6OpenSDA%E9%A1%B5%E9%9D%A2%EF%BC%88%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOPENSDA%22%20target%3D%22_new%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOPENSDA%3C%2FA%3E%EF%BC%89%E4%B8%8A%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E6%88%91%E7%9A%84%E6%9D%BF%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AFOpenSDAV1%EF%BC%8C%E5%9B%A0%E4%B8%BA%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%E9%83%BD%E6%98%AFPEMicro%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%E8%AF%A5%E9%A1%B5%E9%9D%A2%E4%B8%8A%E6%90%9C%E7%B4%A2%E6%88%91%E7%9A%84%E6%9D%BF%E6%9D%A5%E6%9B%B4%E6%96%B0%20OpenSDA%EF%BC%8C%E4%BD%86%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E5%AE%83%E5%88%97%E5%87%BA%E7%9A%84%E5%86%85%E5%AE%B9%E3%80%82%E7%84%B6%E5%90%8E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%B8%BA%20TRK-KEA128%20%E6%9D%BF%20%E6%8F%90%E4%BE%9B%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%E6%88%91%E7%86%9F%E6%82%89%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%96%B0%E7%A8%8B%E5%BA%8F%EF%BC%88%E8%BF%9B%E5%85%A5%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E5%99%A8%E6%A8%A1%E5%BC%8F%E5%B9%B6%E6%8B%96%E6%94%BE%E5%9B%BA%E4%BB%B6%E6%96%87%E4%BB%B6%EF%BC%89%EF%BC%8C%E4%BD%86%E6%9B%B4%E6%96%B0%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%3CP%3E%E8%AE%A9%E6%88%91%E7%89%B9%E5%88%AB%E6%80%80%E7%96%91%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E4%B8%8B%E8%BD%BD%E7%9A%84%E6%96%87%E4%BB%B6%E6%98%AF%3CSTRONG%3E.bin%3C%2FSTRONG%3E%E6%A0%BC%E5%BC%8F%E7%9A%84%E3%80%82%E8%80%8C%E6%A0%B9%E6%8D%AE%E6%81%A9%E6%99%BA%E6%B5%A6%E9%A1%B5%E9%9D%A2%E4%B8%8A%E7%9A%84%E8%A1%A8%E6%A0%BC%EF%BC%8COpenSDAv1%20%E9%9C%80%E8%A6%81%3CSTRONG%3E.sda%20%2F%20.s19%20%2F%20.srec%3C%2FSTRONG%3E%E6%A0%BC%E5%BC%8F%E7%9A%84%E6%96%87%E4%BB%B6%E3%80%82%E6%A0%BC%E5%BC%8F%EF%BC%88%E8%A7%81%E8%A1%A8%E6%A0%BC%E5%92%8C%E4%B8%8B%E8%BD%BD%E9%93%BE%E6%8E%A5%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOPENSDA%3Ftid%3DvanOpenSDA%23nogo%22%20target%3D%22_new%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%EF%BC%9Ahttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOPENSDA%3Ftid%3DvanOpenSDA%23nogo%EF%BC%89%3C%2FA%3E%E3%80%82%E8%BF%9B%E4%B8%80%E6%AD%A5%E6%90%9C%E7%B4%A2%E4%B9%9F%E6%97%A0%E6%B5%8E%E4%BA%8E%E4%BA%8B%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E5%9C%A8%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E9%83%BD%E6%89%BE%E4%B8%8D%E5%88%B0%E6%89%80%E9%9C%80%E7%9A%84%E6%96%87%E4%BB%B6%E6%A0%BC%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E4%B8%BB%E8%A6%81%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%9A%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%B0%86%E8%BF%99%E4%B8%AA%E6%9D%BF%E4%B8%8A%E7%9A%84OpenSDA%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%94%B9%E4%B8%BACMSIS%E5%90%97%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E5%90%97%EF%BC%9F%E6%88%91%E8%AE%A4%E4%B8%BA%E5%BA%94%E8%AF%A5%E5%A6%82%E6%AD%A4%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%B9%8B%E5%89%8D%E8%B4%AD%E4%B9%B0%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%20FRDM-KEAZ128Q8%20%E6%9D%BF%EF%BC%8C%E5%AE%83%E5%B7%B2%E7%BB%8F%E5%9C%A8%20CMSIS%20%E5%9B%BA%E4%BB%B6%E4%B8%8A%E8%BF%90%E8%A1%8C%E4%BA%86%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E4%B8%8D%E8%AE%B0%E5%BE%97%E5%BF%85%E9%A1%BB%E6%89%8B%E5%8A%A8%E5%B0%86%E5%85%B6%E4%BB%8E%20Pemicro%20%E5%88%87%E6%8D%A2%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E8%83%BD%E6%8F%90%E4%BE%9B%E4%BB%BB%E4%BD%95%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%EF%BC%8C%E5%B9%B6%E6%84%9F%E8%B0%A2%E6%82%A8%E8%8A%B1%E6%97%B6%E9%97%B4%E9%98%85%E8%AF%BB%E6%88%91%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183275%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-KEAZ128Q8%20%7C%20OpenSDA%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183275%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255468%22%20target%3D%22_blank%22%3E%40aelmrn%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ECMSIS%E6%9B%B4%E6%96%B0%E4%BA%86%E8%B0%83%E8%AF%95%E5%99%A8%E8%BD%AF%E4%BB%B6%EF%BC%8C%E4%BD%86%E4%B8%8D%E5%8C%85%E6%8B%ACKEA%E7%B3%BB%E5%88%97%EF%BC%88%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FARM-software%2FCMSIS_6%2Freleases%2Ftag%2Fv6.2.0%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%E7%89%88%E6%9C%AC%20CMSIS%206.2.0%C2%B7Arm-Software%2Fcmsis_6%C2%B7GitHub%EF%BC%89%EF%BC%8CKEA%E7%B3%BB%E5%88%97%E7%9A%84%E5%8A%9F%E8%83%BD%E8%B0%83%E8%AF%95%E5%99%A8%E6%98%AFPE%3C%2FA%3E%20M%3CA%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Fopensda%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20icro%EF%BC%88peMicro%20%7C%20%E5%9C%A8%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%B3%BB%E7%BB%9F%E9%A2%86%E5%9F%9F%E5%88%9B%E6%96%B040%E5%A4%9A%E5%B9%B4%EF%BC%89%E3%80%82Flash%20%E7%BC%96%E7%A8%8B%E5%99%A8%E3%80%81%E5%9F%BA%E4%BA%8E%E4%BA%91%E7%9A%84%E3%80%81%E8%87%AA%E5%8A%A8%E7%9A%84%E3%80%81%E5%B8%AE%E6%B4%BE%E7%A8%8B%E5%BA%8F%E5%91%98%E7%AD%89...%3C%2FA%3E%20%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E6%AD%A4%E9%80%A0%E6%88%90%E7%9A%84%E4%B8%8D%E4%BE%BF%E6%B7%B1%E8%A1%A8%E6%AD%89%E6%84%8F%E3%80%82%20%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-KEAZ128Q8%20%7C%20OpenSDA%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181653%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241501%22%20target%3D%22_blank%22%3E%40carlos_o%3C%2FA%3E-%20%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%81%3CBR%20%2F%3E%E6%88%91%E7%9F%A5%E9%81%93%E6%88%91%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8D%E6%94%AF%E6%8C%81%20OpenSDAv2%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%A0%B9%E6%8D%AE%E7%8E%B0%E6%9C%89%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%AE%83%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20OpenSDAv1%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%B0%86%20OpenSDAv1%20%E5%9B%BA%E4%BB%B6%E4%BB%8E%20PEmicro%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20DAP-CMSIS%E3%80%82%E6%88%91%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%EF%BC%8C%E5%8D%B3%E5%B8%A6%E6%9C%89%20DAP-CMSIS%20%E5%9B%BA%E4%BB%B6%E7%9A%84%20FRDM-KEAZ128Q8%EF%BC%8C%E8%AE%A2%E8%B4%AD%E7%9A%84%E6%97%B6%E9%97%B4%E6%AF%94%E9%BB%98%E8%AE%A4%E9%99%84%E5%B8%A6%E7%9A%84%20peMicro%20%E5%9B%BA%E4%BB%B6%E7%9A%84%E6%96%B0%E5%BC%80%E5%8F%91%E6%9D%BF%E8%A6%81%E6%97%A9%E4%B8%80%E4%BA%9B%EF%BC%8C%E4%BD%86%E6%88%91%E8%AE%B0%E5%BE%97%E6%B2%A1%E6%9C%89%E5%9C%A8%E9%82%A3%E5%9D%97%E6%97%A7%E6%9D%BF%E4%B8%8A%E5%B0%86%E5%9B%BA%E4%BB%B6%E4%BB%8E%20peMicro%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20DAP-CMSIS%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%A6%E5%A4%96%EF%BC%8C%E6%88%91%E5%9C%A8%E4%BD%A0%E7%9A%84%E7%BD%91%E9%A1%B5%E4%B8%8A%E4%B9%9F%E6%98%AF%E8%BF%99%E4%B9%88%E6%83%B3%E7%9A%84%20%5B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOPENSDA%3F_gl%3D1*14qlfnx*_ga*MTM5OTYwNDE5OS4xNzU5OTAyNTUy*_ga_WM5LE0KMSH*czE3NTk5MDI1NTIkbzEkZzEkdDE3NTk5MDI4MTgkajIxJGwwJGgxNjMzMjQzMTY5%23TRK-KEA128%5D(https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOPENSDA%3F_gl%3D1*14qlfnx*_ga*MTM5OTYwNDE5OS4xNzU5OTAyNTUy*_ga_WM5LE0KMSH*czE3NTk5MDI1NTIkbzEkZzEkdDE3NTk5MDI4MTgkajIxJGwwJGgxNjMzMjQzMTY5%23TRK-KEA128%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOPENSDA%3F_gl%3D1*14qlfnx*_ga*MTM5OTYwNDE5OS4xNzU5OTAyNTUy*_ga_WM5LE0KMSH*czE3NTk5MDI1NTIkbzEkZzEkdDE3NTk5MDI4MTgkajIxJGwwJGgxNjMzMjQzMTY5%23TRK-KEA128%5D(https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FOPENSDA%EF%BC%9F_gl%3D1*14qlfnx*_ga*mtm5otywnde5os4xnzu5oTayntuy*_ga_wm5le0kmsh*cze3ntk5mdi1ntikbzzzekdde3ntkzzekdde3ntk5ndi4mdi4mdi4mgkajixjggxnjggxnjmzknjmzkty5%20%23TRK-KEAKZMTY5-KEAKZZMTY5%20128)%20**%20%E2%80%9C%E9%80%82%E7%94%A8%E4%BA%8E%20OpenSDAV1%20%E7%9A%84%20CMSIS-DAP%20%E8%B0%83%E8%AF%95%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E2%80%9D%20**%E4%B8%8B%E5%8F%AF%E4%BE%9B%E4%B8%8B%E8%BD%BD%3C%2FA%3E%E7%9A%84%E6%96%87%E4%BB%B6%E5%AE%89%E8%A3%85%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%3CBR%20%2F%3E%E9%80%89%E6%8B%A9%20TRK-KEA128%20%E6%9D%BF%E5%B9%B6%E6%8C%89%20%E2%80%9C%E4%B8%8B%E8%BD%BD%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E2%80%9D%20%E6%97%B6%EF%BC%8C%E4%B8%8B%E8%BD%BD%E7%9A%84%20%E2%80%9C.bin%E2%80%9D%20%E6%96%87%E4%BB%B6%E5%AF%B9%E5%BA%94%E4%BA%8E%20TWR-KM35Z75M%20%E6%9D%BF%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E7%82%B9%E5%87%BB%E7%9B%B8%E9%82%BB%E7%9A%84%20%22%E6%BA%90%E4%BB%A3%E7%A0%81%20%22%E6%8C%89%E9%92%AE%E4%BC%9A%E8%B7%B3%E8%BD%AC%E5%88%B0%E4%B8%80%E4%B8%AA%E5%B7%B2%E5%88%A0%E9%99%A4%E7%9A%84%E9%A1%B5%E9%9D%A2%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E8%BF%99%E4%BA%9B%E6%96%87%E4%BB%B6%E7%A1%AE%E5%AE%9E%E6%9C%89%E8%AF%AF%EF%BC%8C%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%9B%B4%E6%96%B0%E4%B8%80%E4%B8%8B%EF%BC%9F%3CBR%20%2F%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%83%BD%E5%9B%9E%E7%AD%94%E5%A6%82%E4%BD%95%E5%B0%86%20OpenSDA%20%E5%9B%BA%E4%BB%B6%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%8E%20PEmicro%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20CMSIS-DAP%EF%BC%88%E8%AF%B4%E6%98%8E%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%88%91%E5%B9%B6%E4%B8%8D***%E5%B8%8C%E6%9C%9B%E5%B0%86%20OpenSDA%20%E7%89%88%E6%9C%AC%E4%BB%8E%20v1%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20v2%20%E6%88%96%E7%B1%BB%E4%BC%BC%E7%89%88%E6%9C%AC%EF%BC%89%EF%BC%8C%E6%88%91%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3C%2FP%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-KEAZ128Q8%20%7C%20OpenSDA%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181511%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255468%22%20target%3D%22_blank%22%3E%40aelmrn%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%AF%A5%E6%9D%BF%E6%9C%AA%E5%88%97%E5%87%BA%EF%BC%8C%E5%AE%83%E5%B0%86%E4%B8%8D%E6%94%AF%E6%8C%81%20OpenSDAv2%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%E7%94%B1%E6%AD%A4%E5%8F%AF%E8%83%BD%E9%80%A0%E6%88%90%E7%9A%84%E4%B8%8D%E4%BE%BF%EF%BC%8C%E6%88%91%E4%BB%AC%E6%B7%B1%E8%A1%A8%E6%AD%89%E6%84%8F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2179469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-KEAZ128Q8%20%7C%20OpenSDA%20problem%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B9%9F%E6%9C%89%E7%B1%BB%E4%BC%BC%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B8%8C%E6%9C%9B%E8%83%BD%E6%9C%89%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
