FRDM-KEAZ128 can't connect to the S32DS
696 次查看
elder_atom
At first ,FRDM-KEAZ128 can connect to the S32DS normally, then I drag a MSD-DEBUG-FRDMP-KEAZ128Q80_Pemicro_v118.SDA file to the board in the bootloader mode and when I download the project to the board ,I find the board can't connect to the S32DS.
Thank you!
561 次查看
Hello Li Yinwei ,
I use the same file to update the bootloader, it still can work well.
Please change to a new workspace through File ->Switch Workspace ,
then create a simple new project to have a try.
Also please check the Device Manager whether the board been detected.
Alice
562 次查看
Hello Li Yinwei ,
Alice
