FRDM-KE06Z Pinouts
FRDM-KE06Z Pinouts
jun1
Contributor V
Hi.
I use FRDM-KE06Z. I want to know this pinout, but the quick reference for this board says that PINOUT is a spreadsheet. Where can I download it?
Thank you.
jun
kerryzhou
Hi jun yamada ,
 As I know, we don't have that pinout file.
  But, you totally can refer to the schematic, you will find all the IO connection to the MCU in the FRDM-KE06 board.
You can find the FRDM-KE06 related material from this link:
FRDM-KE06Z|Freedom Development Platform|Kinetis® MCU | NXP
  About the detail pin function, you also can read the KE06 reference manual.
chapter Chapter 10 Signal Multiplexing and Signal Descriptions.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
kerryzhou
Hi jun yamada ,
Wish it helps you!
Kerry
jun1
Contributor V
Thank you very much.
solved.
