FRDM-KE06Z Bootloader Error
3,248件の閲覧回数
jun1
Contributor V
Hi.
Thank you for your help.
FRDM-KE06Z will cause an error. When the USB cable is connected, the LED blinks 8 times and then stops and repeats. The LASTSTAT.TXT at that time is programming ...
Attach the INFO file at that time.
Please tell me what to do.
jun.
3,102件の閲覧回数
jingpan
Hi jun,
Please download FRDM-KE06 openSDA firmware application from OpenSDA Serial and Debug Adapter | NXP .
There is a guide in this page shows how to copy the application into openSDA.
Jing
2 返答(返信)
3,103件の閲覧回数
jingpan
Hi jun,
Jing
3,102件の閲覧回数
aleedrc
Hi! I tried to copy the application following step by step , and when I reconnect the usb nothing happens, im using windows 10
and im using FRDM-KL46Z
