FRDM-K66F Run @180MHz
a8Chcx
I am running RRDM-K66F MCU at 120MHz and everything is working fine.
For now, I am trying to run it at 180MHz.
Can anybody tell me if there is any potential issue with the high speed?
Christie
EdwinHz
Hi @a8Chcx,
There shouldn't be any issues, as the 180MHz frequency is still within the operating ranges of the MK66 MCU.
BR,
Edwin.
a8Chcx
Hi Edwin,
I checked the document and says there is the restriction for flash programming and erasing for high speed. Does it means I can't do the flash programming and erasing?
If I want to do the flashing programming and erasing, I have to switch to slower speed?
Christie
EdwinHz
Hi @a8Chcx,
Could you please clarify what document you are referring to?
a8Chcx
Hi Edwin,
It is on section 8.7 of "K66P144M180SF5RMV2" manal.
The flash memory on this device should not be programmed or erased while operating in
High Speed Run or VLPR power modes.
Christie
EdwinHz
Hi @a8Chcx,
Thanks for clarifying. Yes, this is a restriction on the HSRUN (180MHz) mode. If I want to do the flashing programming and erasing, you have to switch to a lower speed.
BR,
Edwin.
