FRDM-K64 USB_CDC_VCOM ANDROID PROBLEM
1,007件の閲覧回数
francescoferrar
I'm working with kds + ksdk 2.0 + FRDM-K64 board.
If I run "dev_cdc_vcom_lite_bm_frdmk64f" example and connect the USB cable from PC (Linux/Windows) to FRDM-K64, all work fine.
If I connect the USB cable from Tablet Android  to FRDM-K64, not work.
I used "USB Serial Monitor Lite" android app and when I press send button the application blocks.
Has anyone connected a android device to MCU Kinetis, using USB?
Thanks!
Francesco
0 返答(返信)
