FDB K64 J-Link Debugger Failed to Work
1,616 次查看
Designer11
Hi All,
I'm having an issue with one of the two K64 Freedom boards. Regardless what i do. I can not get this one board to enter debug mode. I've tried to flash it with the latest version of Bootloader from J-Link, and removed all the breakpoints.
D
1,534 次查看
BlackNight
Have you already checked there is no arm-none-eabi or Segger J-Link executable hanging around, e.g. point 9 in
Debugging Failure: Check List and Hints | MCU on Eclipse
And have you tried with an external probe already (not using the OpenSDA circuit)?
I hope this helps,
Erich
