FAQ-28993 and print via BDM
1,626 次查看
luc28
Looking for FAQ-28993 but cannot find it.
It is suppose to explain how to print via the BDM (or JTAG).
Working on the Kinetis K10 and multilink debugger from P&E.
Thx
标记 (4)
1,538 次查看
luc28
In CW 10.3, when you create a project there an I/O support: Debbuger Console.
I suspect this is what you need to use.
I have not tryed it.
1,538 次查看
CrasyCat
Specialist III
Hello
FAQs have been removed from the system and should be integrated in the community portal some times in the future.
I checked internally and FAQ-28993 is specific to Coldfire MCU. It does not apply to Kinetis so it would not help in your case.
Try getting assistance from the CodeWarior for MCU community and if this does not work, you can submit a service request through our on line support web page.
CrasyCat
