EzPRog Codewarrior Project
3,532件の閲覧回数
bobsawyer
I have been looking for the Codewarrior 10.x version of The EzProg project for the KwitStik K40 board.
I is referenced as "available" in AN4406, but I can't seem to find it.
I would appreciate any help in finding this.
Thanks!
タグ(1)
3,203件の閲覧回数
BobS
I did find this post:
KwikStik-based EzPort programmer - Sources of tutorial
There appears to be source code that can be downloaded .
Thanks!
4 返答(返信)
3,203件の閲覧回数
pavel_sadek
hi
it is available,
just go to www.freescale.com and do the keyword search for "AN4406"
you will get it in the very first result, just at the end of the line, see the picture
Pavel
3,203件の閲覧回数
BobS
Pavel,
Thank you for your response!
I had downloaded the software zip some time ago, but it appears to have only Keil projects in it.
I will try again with the link you showed.
I appreciate the help!!!!
3,203件の閲覧回数
BobS
Pavel,
I downloaded the zip file, but it appears to be the same as I got last time.
I don't see anything I recognize as Codewarrior 10.x.  The readme.txt file refers to IAR, not Keil - sorry!
Also, it doesn't appear that there is any source code included.  Am I just missing something?
Thanks!
3,203件の閲覧回数
BobS
Thanks!
