EXAMPLE STARTUP CODE IN assembly language for KEA-128
vignesh_vb_7
    I need an example startup code in assembly for KEA-128. I am using CodeWarrior IDE.
santiago_gonzal
You can create it yourself using the wizard. If you select assembly as the language you will get a very simple project.
I attach it for your reference.
Santiago
vignesh_vb_7
Hi Santiago,
                    I want the startup code to be in assembly language.If you change it as assembly in the wizard only the main file changes into assembly language.Please let me know how to change the startup code in assembly language(like __arm_start.c, __arm_end.c files etc).
vignesh_vb_7
Thank you Santiago.Can you tell me how to do that ?Is there any application note or any documents or videos on how to create assembly language  Startup code in KEA-128
