I want to use SWD_DIO pin to PTA4.
but when i debug, if code go through this code, debugger shows me 'no source available for "__isr_vector() 0x4"'
and debug stops.
why this problem happen? datasheet says SWD_DIO pin is 'Serial Wire Debug Data input/output', so debug process can't go more?
已解决! 转到解答。
Yes, if you map a pin used by SWD/Debug as a GPIO pin, you won't be able to debug any more.
