EEPROM emulation by using FLASH memory?
5,980 次查看
pengliang
Hi all,
Does anyone know how to use flash memory emulate EEPROM? if yes, could you provide sample code tutorial?
Thank you
3,469 次查看
apanecatl
Senior Contributor II
You can download our flash drivers for EEPROM emulation in Non Flex NVM memory for Kinetis and ColdFire devices:
TFS Flash Driver Software for Kinetis and ColdFire+ Microcontrollers
If you are looking for EEPROM emulation using Flex NVM memory check the following App Note:
http://cache.freescale.com/files/32bit/doc/app_note/AN4282.pdf
4 回复数
3,470 次查看
apanecatl
3,469 次查看
pengliang
Thank you for the information.
Does the driver support Kinetis L family? thank you
3,469 次查看
alejandrolozan1
Yes, you can even find an example in the installation folder of the C90TFS driver.
(Installation path)\Standard Software Driver vBeta033\C90TFS\Demos\L2K
3,469 次查看
apanecatl
I'm not pretty sure however the flash routines should be identical, so most likely yes
