Does anyone have an example code to work with the Ethernet module in the FRDM K64F on KDS enviroment? Thanks
3,208 次查看
carlosorozco
5 回复数
2,746 次查看
mjbcswitzerland
Specialist V
2,746 次查看
carlosorozco
I did it, i couldn't see nothing that can help me
2,746 次查看
mjbcswitzerland
Specialist V
Hi Carlos
Here is a screen shot of the page with the details that you missed:
Plus
It contains Ethernet code for your board and also a VisualStudio simulator which allows testing the Ethernet module in real-time on your PC.
More details here: https://community.freescale.com/message/400458#400458
Mark
2,746 次查看
carlosorozco
Can you give me the password to unzip the uTaskerKinetisV1.4.6 please? i requested it but i haven't recived it. Thanks
2,746 次查看
mjbcswitzerland
Specialist V
Hi Carlos
V1.4.7 is available for download without password protection. It is a newer version than V1.4.6 and has more features and device support.
You should receive the password for all archives shortly, but you will only need it for retrieving older versions in case of the need to unwind versions (which you won't as a new user).
Mark
