Do the MCUs support any other FC version
1,895 次查看
arunkannan
MCUs used
MKL16Z128VLH4
MKV10Z128VLF7
MKL16Z128VFT4
MKV10Z128VLF7
MKV10Z64VLF7
As per NXP support our MCUs support Section 5 FC version 3  bootloader implementation.
1. Is there any other FC version supported by the MCUs? If so, list them
2. Do the MCUs support Section 7 protocol version5, Kinetis?
3 回复数
1,765 次查看
Hello @arunkannan
1) You can also choose Kinetis bootloader:
https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true
2) AN2295 doesn't support KV series, support K and L series.
Alice
1,832 次查看
Hello @arunkannan
Please describe your question more detail, where is the "FC version" meaning?
" Section 7 protocol version5"->> which doc?
Alice
1,799 次查看
arunkannan
nxp.com/docs/en/application-note/AN2295.pdf
The FC versions are given in above AN2295 document
