Delay in Updating Value on Webpage using MQX RTOS
Santo
I have Ported MQX RTOS httpsrv example on TWRK60 Development Board and checking the Web Page.
But The Values in Webpage are updating very slow and sometimes the values don't update for a very long time(approx - 5secs)
pls let me know what could be the issue
danielchen
I would suggest you check your network connections. whether there is a IP address conflict
Santo
Sorry for the delay in the reply . i have verified and there is no IP address conflict.the problem still persists and the system is in production line.its a huge bug which needs to be corrected. please suggest a solution.
