D4D GUI Quich Stard Guide
2,132件の閲覧回数
Thommi_Tulpe
has anyone a good tuturial to work with the LCD and Touchscreen driver.
I downloaded some from the fsl hompage. I also downloaded the official demos, but I
did not understand the most. I can run the demos on my TWR-K60N512 with the TWR-LCD.
I did not know in wich file I have to place my buttons, textfields and so on. I know other
GUIs e. g. the GUI from the CodeWarrior for PalmOS. There it is very easy to create a screen, buttons and so on.
But for this I need e tutorial or a good Quick Start Guide.
1,681件の閲覧回数
anthony_huereca
Try using the attached zip file which has some labs done for training at ESC last year. The projects were built for TWR-LCD stand-alone use, but the exact same concepts apply when using eGUI on the K60. It goes through how to create a simple project, use click callbacks, and use the Image Convertor tool to import your own images.
1,681件の閲覧回数
elisamejia
Hi!
I am trying to get started with TWR-LCD-RGB using the K53, but I haven´t find any useful tutorial, quick start guide or any help regarding the use of eGUI and CodeWarrior without MQX.
Do you know where can I find one?
Thanks in advance!
