Curl for FRDM-K66
Curl for FRDM-K66
a8Chcx
I am using K66 MCU, MCUXpreeso IDE with MbedTLS and LWIP for my controller.
I am trying to build "curl" client to access my https server. Can anyone share any project with me?
Thank you very much!
Christie
Pavel_Hernandez
Hello a8Chcx
Unfortunately, the only client examples available are the ones included in our SDK. I apologize for the inconvenience this may cause you.
Pavel_Hernandez
a8Chcx
Hi Pavel,
I tried https client sample project in RT1050 SDK and get teh follwoing error:
"TLS Web Client Authentication x509_verify_cert() returned -9984 (-0x2700)"
Can you tell me what it happens and how to fix it?
Christie
a8Chcx
I tried again and got the client cert errors. Please check the attached doc to see the output on hyper-terminal.
Can you tell where the problem is and how to fix it?
Christie
